2018-11-13
07:35 PM
2022-10-05
01:31 PM
Daniel Kassai
GSErrCode ModifyZonePoz(const API_Guid &guid)
API_Element element;
API_Element mask;
GSErrCode err;
BNZeroMemory(&element, sizeof(API_Element)); // AC17-AC22 element.header.index
ACAPI_ELEMENT_MASK_CLEAR (mask);
ACAPI_ELEMENT_MASK_SET (mask, API_ZoneType, pos);
//ACAPI_ELEMENT_MASK_SET(mask, API_ZoneType, roomName);
element.zone.pos.x = 5.0;
element.zone.pos.y = 10.0;
//CHCopyC ("test", element.zone.roomName);
element.header.guid = guid; // в заголовок поместить Guid
element.header.typeID = API_ZoneID; // обязательно !
err = ACAPI_Element_Change(&element, &mask, NULL, 0, true);
WriteReport("ACAPI_Element_Change %ld", err);
return err;
What threatens me if, instead of this function, I copy all the properties of the zone and change the memo, then create a new one? ACAPI_Element_Create?Solved! Go to Solution.
2018-11-14 09:29 PM
GSErrCode ModifyZonePos (const API_Guid& guid, const API_Coord& newPos)
API_ElementMemo memo;
GSErrCode err;
BNZeroMemory (&element, sizeof (API_Element));
BNZeroMemory (&memo, sizeof (API_ElementMemo));
// get actual zone
err = ACAPI_Element_Get (&element);
if (err == NoError)
err = ACAPI_Element_GetMemo (element.header.guid, &memo);
if (err != NoError)
return err;
// modify pos and create a new zone
element.zone.pos = newPos;
err = ACAPI_Element_Create (&element, &memo);
ACAPI_DisposeElemMemoHdls (&memo);
// delete original zone
API_Elem_Head** heads = (API_Elem_Head**) BMhAllClear (sizeof (API_Elem_Head));
(*heads).guid = guid;
ACAPI_Element_Delete (heads, 1);
BMhKill ((GSHandle*) &heads);
return err;
2018-11-14 09:29 PM
GSErrCode err;
// get actual zone
if (err == NoError)
if (err != NoError)
return err;
return err;
2018-11-15 04:55 PM
GSErrCode ModifyZonePos(const API_Guid& guid, const API_Coord& newPos)
GSErrCode err;
BNZeroMemory(&memo, sizeof(API_ElementMemo));
// get actual zone
err = ACAPI_Element_Get(&element);
if (err == NoError)
err = ACAPI_Element_GetMemo(element.header.guid, &memo);
if (err != NoError)
return err;
// delete original zone, before create a new zone, if not want get alert
API_Elem_Head** heads = (API_Elem_Head**)BMhAllClear(sizeof(API_Elem_Head));
(*heads)[0].guid = guid; // 0 -1 zones
ACAPI_Element_Delete(heads, 1);
BMhKill((GSHandle*)&heads);
err = ACAPI_Element_Create(&element, &memo);
ACAPI_DisposeElemMemoHdls(&memo);
return err;
2018-11-15 06:11 PM
ufo_ru wrote:Please note that the parameters of ACAPI_Element_Delete will change in ARCHICAD 23, so you won't have to bother with pointers anymore:
considering my level of understanding of x2 pointers
// Before AC23: GSErrCode ACAPI_Element_Delete (API_Elem_Head **elemHead, Int32 nItem); // Since AC23: GSErrCode ACAPI_Element_Delete (const GS::Array<API_Guid>& elemGuids);The sample code in API23 will be much shorter:
API_Element element = {};
API_ElementMemo memo = {};
GSErrCode err;
// get actual zone
if (err == NoError)
if (err != NoError)
return err;
ACAPI_Element_Delete({guid});
return err;
