2021-05-25
11:25 AM
2021-09-14
09:36 AM
Noemi Balogh
GS::Array<API_Guid> drawingList; err = ACAPI_Element_GetElemList(API_DrawingID, &drawingList); API_Element mask; ACAPI_ELEMENT_MASK_CLEAR(mask); ACAPI_ELEMENT_MASK_SET(mask, API_DrawingType, nameType); ACAPI_ELEMENT_MASK_SET(mask, API_DrawingType, numberingType); ACAPI_ELEMENT_MASK_SET(mask, API_DrawingType, name); ACAPI_ELEMENT_MASK_SET(mask, API_DrawingType, customNumber); ACAPI_ELEMENT_MASK_SET(mask, API_DrawingType, bounds); ACAPI_ELEMENT_MASK_SET(mask, API_DrawingType, ratio); API_Element element = {}; element.header.guid = drawingGuid; err = ACAPI_Element_Get(&element); if (err == NoError) { element.drawing.nameType = APIName_CustomName; element.drawing.numberingType = APINumbering_CustomNum; CHCopyC("Test", element.drawing.name); CHCopyC("Test", element.drawing.customNumber); //----------------------------------------------------------------------------- //Right now doing it manually //layout size = 392 and drawingSize = 680 //ratio = layout size / drawing size // = 392 / 680 = .57647 //--------------------------------------------------------------------------------- element.drawing.ratio = .57647; element.drawing.bounds.xMin = 0.1010; element.drawing.bounds.xMax = 0.4929; element.drawing.bounds.yMin = 0.0140; element.drawing.bounds.yMax = 0.4059; err = ACAPI_Element_Change(&element, &mask, nullptr, 0, true);Can anyone kindly help me to figure out what's doing wrong and how can I update the bound values here?
Solved! Go to Solution.
2021-05-31 12:30 PM
ACAPI_ELEMENT_MASK_SET(mask, API_DrawingType, isCutWithFrame); //.... element.drawing.isCutWithFrame = true; //.... if (element.drawing.poly.nCoords != 5 || element.drawing.poly.nSubPolys != 1 || element.drawing.poly.nArcs != 0) { DBPrintf("Can only do rectangular polygons for now!"); return; } API_ElementMemo memo; err = ACAPI_Element_GetMemo (element.header.guid, &memo); if (err != NoError) { DBPrintf ("Couldn't get Element Memo!"); ACAPI_DisposeElemMemoHdls(&memo); return; } if (memo.coords != nullptr && memo.pends != nullptr) { (*memo.coords)[1].x = element.drawing.bounds.xMin; (*memo.coords)[1].y = element.drawing.bounds.yMin; (*memo.coords)[2].x = element.drawing.bounds.xMax; (*memo.coords)[2].y = element.drawing.bounds.yMin; (*memo.coords)[3].x = element.drawing.bounds.xMax; (*memo.coords)[3].y = element.drawing.bounds.yMax; (*memo.coords)[4].x = element.drawing.bounds.xMin; (*memo.coords)[4].y = element.drawing.bounds.yMax; (*memo.coords)[5].x = (*memo.coords)[1].x; (*memo.coords)[5].y = (*memo.coords)[1].y; } // Adapt your Element_Change line to this err = ACAPI_Element_Change (&element, &mask, &memo, APIMemoMask_All, true); ACAPI_DisposeElemMemoHdls(&memo);
2021-05-31 12:30 PM
2021-06-18 01:06 PM
2021-07-01 10:49 AM
