Is there a way for an addon to unload itself?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-07-31
04:08 AM
2021-09-15
10:30 AM
Noemi Balogh
I was looking to unload the addon itself. But the apx file is locked while the addon is loaded. How could I unload the addon in that case?
Solved! Go to Solution.
- Labels:
Add-On (C++)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-13 05:29 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-31 04:16 AM
This will allow you to load or un-load add-ons without actually removing the files.
Or close Archicad and you should have full control of the actual file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-31 05:47 AM
Barry wrote:Is there an API to unload it?
Use the Add-on Manager in Archicad.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-31 06:00 AM
Try the Add-on Manager - it is part of Archicad.
It may depend on the add-on you are trying to stop.
If it can't be done here you have to close Archicad and delete or move the file from the add-on folder manually.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-31 06:07 AM
Barry wrote:Thank you! Maybe I haven't explain it clearly: I am writing an addon which should update itself. However, I couldn't find an api to do that. Is there a way to achieve that goal using the given apis?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-31 07:04 AM
Yes, sorry I missed that this was in the developer's forum.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-31 10:13 AM
We've written our installer to check if the target version of Archicad is running and ask them to quit first if it is. In the current application structure, I don't think self-updating is possible.
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-31 11:15 AM
Ralph wrote:OK. Thank you.
I don't know any way to do this. Given the way Archicad calls the sequence ofCheckEnvironment, RegisterInterfaceand Initializeduring startup, I suspect you wouldn't be able to integrate the update into an active session anyway.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-13 05:29 AM
