Archicad C++ API
Re: How can I do it like fit to skin? sect_fill "insulation 01"
LeeJaeYoung
It seems that 3D Script does not support Fit to Skin of Building Material, is that correct?
Thanks for the reply.
AC27 on window 11
runxel
Hero
For textures you'd need to look into GDL primitives and TEVE.
However as far I am aware this has no effect on the internal engine, which also drives the section/elevation/3d doc generation.
So all in all: that's not possible.
I also need to have Sect Fill's Fill Orientation and a scale that can be adjusted to fit the thickness, but it doesn't seem to be in gdl yet.
Thank you so much for your reply.
AC27 on window 11
