ā2022-02-05 05:40 AM
It seems that 3D Script does not support Fit to Skin of Building Material, is that correct?
Thanks for the reply.
ā2022-02-05 08:39 PM
For textures you'd need to look into GDL primitives and TEVE.
However as far I am aware this has no effect on the internal engine, which also drives the section/elevation/3d doc generation.
So all in all: that's not possible.
ā2022-02-06 03:21 AM
I also need to have Sect Fill's Fill Orientation and a scale that can be adjusted to fit the thickness, but it doesn't seem to be in gdl yet.
Thank you so much for your reply.
