Archicad C++ API
[SOLVED] APIDb_NewDatabaseID returns APIERR_REFUSEDCMD
ReignBough
As the title says. This appears on 6005. When I ran my add-on on 3012, it is working fine.
The code is just the same as the one on the documentation.
I also tried the sample Database_Control, but it works on both 3012 and 6005. What make it return APIERR_REFUSEDCMD?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
1 REPLY 1
ReignBough
Found it.
It was in a function that is between a undo-able. (Actually, it's in a function (0) that is called by a function (1) that is called by a function (2) that is called by a function (3) that is inside undo-able).
But this set-up is okay with 3012.
~ReignBough~
