[SOLVED] How to interact to TabControl(NormalTab) controls
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-02-25
01:02 PM
‎2023-08-01
01:50 PM
Doreena Deng
‎2015-02-25
01:02 PM
Hi
I have a NormalTab control in my dialog.
There is a TextEdit control in NormalTab.
First I want to know to how I should declare the controls of the NormalTab and second get the TextEdit data in TestSettingsPageObserver class.
Here is my code.
resource file
Here is my code.
resource file
'GDLG' 32511 Modal 0 0 444 174 "Upload IFC" { /* [ 1] */ NormalTab 0 0 428 148 32512 NoIcon "New" 32513 NoIcon "Existing" /* [ 2] */ Button 260 106 75 23 LargePlain "Cancel" /* [ 3] */ Button 341 106 75 23 LargePlain "Upload" } 'DLGH' 32511 DLG_32511_Upload_IFC { 1 "" uploadTabControl 2 "" btnUpload 3 "" btnCancel } 'GDLG' 32512 TabPage 0 0 428 100 "" { /* [ 4] */ LeftText 13 23 84 13 LargePlain "Model file name:" /* [ 5] */ TextEdit 104 18 293 20 LargePlain 256 /* [ 6] */ Separator 13 53 385 1 } 'DLGH' 32512 TabPage_32512 { 4 "" lblModelName_New 5 "" txtModelName 6 "" seperator_2 } 'GDLG' 32513 TabPage 0 0 428 100 "" { /* [ 7] */ LeftText 13 23 84 13 LargePlain "Model file name:" /* [ 8] */ PopupControl 104 18 293 20 144 0 /* [ 9] */ Separator 13 53 385 1 } 'DLGH' 32513 TabPage_32512 { 7 "" lblModelName_Existing 8 "" comboModelName 9 "" seperator_2 }ExportDialog.h
#define IID_EXPORT 32511 #define IDT_NORMALTAB 1 #define IDB_BTN_CANCEL 2 #define IDB_BTN_UPLOAD 3 #define IDT_MODELNAME 5 #define IDC_EXISTING_MODEL 8 class ExportDialog : public DG::ModalDialog { friend class TabControlObserver; private: DG::NormalTab m_TabControl; DG::TextEdit m_txtModelName; DG::Button m_btnCancel; DG::Button m_btnSave; DG::PopUp m_comboModelName; TabControlObserver *tabControl; public: ExportDialog(); ~ExportDialog(); private: protected: private: ExportDialog(const ExportDialog&); const ExportDialog& operator=(const ExportDialog&); //Disabled }; // ----------------------------------------------- TabControlObserver ----------------------------------------------- class TabControlObserver : public DG::PanelObserver, public DG::NormalTabObserver, public DG::ButtonItemObserver, public DG::CompoundItemObserver { private: ExportDialog* mDialog; protected: // DG::PanelObserver virtual void PanelOpened (const DG::PanelOpenEvent& ev) override; // DG::ButtonItemObserver virtual void ButtonClicked (const DG::ButtonClickEvent& ev) override; public: explicit TabControlObserver (ExportDialog* mainDialog); ~TabControlObserver (); };ExportDialog.cpp
ExportDialog::ExportDialog() : ModalDialog (ACAPI_GetOwnResModule (), IID_EXPORT, InvalidResModule), m_TabControl(GetReference (), IDT_NORMALTAB), m_txtModelName(GetReference (), IDT_MODELNAME), m_btnCancel(GetReference (), IDB_BTN_CANCEL), m_btnSave(GetReference (), IDB_BTN_UPLOAD), m_comboModelName(GetReference (), IDC_EXISTING_MODEL) { tabControl = new TabControlObserver(this); m_TabControl.Attach(*tabControl); } ExportDialog::~ExportDialog() { //delete tabControl; } //-------------------------- Class TabControlObserver ----------------------- TabControlObserver::TabControlObserver (ExportDialog* mainDialog): mDialog (mainDialog) { mDialog->Attach (*this); AttachToAllItems (*mDialog); } TabControlObserver::~TabControlObserver () { mDialog->Detach (*this); DetachFromAllItems (*mDialog); } void TabControlObserver::PanelOpened (const DG::PanelOpenEvent& /*ev*/) { mDialog->SetClientSize (mDialog->GetOriginalClientWidth (), mDialog->GetOriginalClientHeight ()); mDialog->m_TabControl.SetClientSize(mDialog->GetOriginalClientWidth (),(mDialog->GetOriginalClientHeight () / 2) - mDialog->m_btnCancel.GetHeight()); } void TabControlObserver::ButtonClicked (const DG::ButtonClickEvent& ev) { // Close dialog with acceptance if (ev.GetSource () == &mDialog->m_btnCancel) { mDialog->PostCloseRequest (DG::ModalDialog::Accept); } else if ( ev.GetSource() == &mDialog->m_btnSave ) { //here I need to get mDialog->m_txtModelName text GS::UniString temp = mDialog->m_txtModelName.GetText(); // this value always comes empty } }My goal is to get mDialog->m_txtModelName information in ButtonClicked function.
Labels:
- Labels:
Add-On (C++)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-25 01:48 PM
‎2015-02-25
01:48 PM
In GRC resource file the ID of the items are sequence numbers in a resource scope.
So please modify your GRC resource file like this:
And don't forget to change the IDs in ExportDialog.h header file also!
Regards,
Tibor
'GDLG' 32511 Modal 0 0 444 174 "Upload IFC" { /* [ 1] */ NormalTab 0 0 428 148 32512 NoIcon "New" 32513 NoIcon "Existing" /* [ 2] */ Button 260 106 75 23 LargePlain "Cancel" /* [ 3] */ Button 341 106 75 23 LargePlain "Upload" } 'DLGH' 32511 DLG_32511_Upload_IFC { 1 "" uploadTabControl 2 "" btnUpload 3 "" btnCancel } 'GDLG' 32512 TabPage 0 0 428 100 "" { /* [ 1] */ LeftText 13 23 84 13 LargePlain "Model file name:" /* [ 2] */ TextEdit 104 18 293 20 LargePlain 256 /* [ 3] */ Separator 13 53 385 1 } 'DLGH' 32512 TabPage_32512 { 1 "" lblModelName_New 2 "" txtModelName 3 "" seperator_2 } 'GDLG' 32513 TabPage 0 0 428 100 "" { /* [ 1] */ LeftText 13 23 84 13 LargePlain "Model file name:" /* [ 2] */ PopupControl 104 18 293 20 144 0 /* [ 3] */ Separator 13 53 385 1 } 'DLGH' 32513 TabPage_32513 { 1 "" lblModelName_Existing 2 "" comboModelName 3 "" seperator_2 }
Regards,
Tibor
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-25 04:26 PM
‎2015-02-25
04:26 PM
Thank you for the response, but your answer is not helpful because I changed but it again doesn't work and also is it correct to have two control with the same ID in a class ?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-25 04:44 PM
‎2015-02-25
04:44 PM
ggiloyan wrote:
is it correct to have two control with the same ID in a class?
No, each item must have unique ID in a class.
BUT you must define a new class for each 'GDLG' resource!
So if you have 1 Modal dialog and 2 TabPage in your GRC file, then you should have 3 classes.
The example code from Tamás Zolnai in the other topic (How to create a TabControl) is imperfect.
I will fix that code, please be patient!
