Archicad C++ API
Structural Display List and Scale List
Nayan
I am trying to show available Structure Display options and Scale options in Popup control. But can't find any function that return the the list of Structure Display and Scale configuration.
Though I have found "APIEnv_​GetStructureDisplayID" that returns structure display options for the current database and "APIDb_​GetDrawingScaleID" returns the drawing scale of the current database.
But I need to find the list.
Can anyone kindly help me on this?
Here are the images that I am trying to achieve.
Viktor Kovacs
The possible values for structure display are simply the possible values of this enum:
typedef enum {
	API_EntireStructure,
	API_CoreOnly,
	API_WithoutFinishes,
	API_StructureOnly
} API_StructureDisplay;
Scale is a bit trickier. It is stored as a single double value so there is no list of scales (it can be custom). I think this scale list is only a UI magic to make easy to set predefined scales.
1 REPLY 1
Viktor Kovacs
typedef enum {
	API_CoreOnly,
	API_StructureOnly
