2006-06-20
03:09 PM
2023-08-07
11:13 AM
Doreena Deng
bool abort = false;
CTestWindow window(abort); //modeless window with access to "abort"
for (int i = 0; (i < 10) && !abort; i++)
Sleep(500);
PRINT(GET(i));
2006-06-20 06:32 PM
2006-06-20 09:33 PM
Akos wrote:
Try to use a palette instead. Modeless dialogs are special to ArchiCAD.
class CTest3Window
public:
CTest3Window(); //creates a pallette with "DGCreateBlankPalette"
~CTest3Window();
void live(); //invokes "DGGetMousePosition"
static short int DGCALLBACK mainEventHandler(
short message,
short dialId,
short itemId,
long userData,
long msgData
private:
short mDialogId;
CTest3Window::CTest3Window()
mDialogId = DGCreateBlankPalette (
200, // hSize,
200, // vSize,
DG_DLG_NOGROW, // growFlag,
DG_DLG_CLOSE, // closeFlag,
0, // captionFlag,
DG_DLG_NORMALFRAME, // frameFlag,
this->mainEventHandler,// dCallBack,
0 //userData
DGShowModelessDialog(mDialogId);
DGBeginProcessEvents(mDialogId);
DGSetModelessDialogStatus(mDialogId, DG_DS_ENABLED);
CTest3Window::~CTest3Window()
DGEndProcessEvents(mDialogId);
DGDestroyModelessDialog(mDialogId);
void CTest3Window::live()
DGMousePosData mpd;
short mouseStatus = DGGetMousePosition(mDialogId, &mpd);
To make the loop breakable try calling something like DGGetMousePosition inside the loop; that lets other event handlers run.
window.live(); //invokes "DGGetMousePosition"
Sleep(500);
The example you are referring to is the test application for the Dialog Manager (a.k.a DG) module.
2006-06-22 05:35 PM
John wrote:
The process-window which could be created with "ACAPI_Interface(APIIo_InitProcessWindowID,.." does not seem to work properly.
bool abort = false;
short nPhase = 1;
long maxval = 100;
ACAPI_Interface (APIIo_InitProcessWindowID, "incremental search", &nPhase);
ACAPI_Interface (APIIo_SetNextProcessPhaseID, "working...", &maxval);
for (int i = 0; (i < maxval) && !abort; i++)
Sleep(500);
PRINT(GET(i));
ACAPI_Interface(APIIo_SetProcessValueID, &i, NULL);
if (ACAPI_Interface(APIIo_IsProcessCanceledID, NULL, NULL))
abort = true;
ACAPI_Interface (APIIo_CloseProcessWindowID, NULL, NULL);
2006-06-24 10:14 AM
John wrote:John,
Now, I am using "APIIo_InitProcessWindowID" after all...
It takes a long time before the process-window appears.
So if the process does not takes long enough you don't see this window. Thats why i thought it would not work.
John wrote:The crux of the problem is that much of ArchiCAD has not been designed to support threading. That's why it crashes when a separate thread attempts to access the database.
[Threads]
An other way i tried was the following:
I coded a Status-Window which is able to invoke the method whose status is to be monitored in a new thread.
But there were several problems:
1. The thread I used is not OS-independent and I think you should avoid OS-specific code in AC-Addons.
2. ArchiCAD often crashes, if the method running in the thread is selecting elements or changing the AC-database.
