the file is an outdated add-on that cannot be used with this
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-06-12 03:30 PM - last edited on ‎2023-08-03 09:48 AM by Doreena Deng
everytime I try to load a simple add-on with AC13 I get this message:
"the file is an outdated add-on that cannot be used with this archicad version"
I tried everything.
- Labels:
Add-On (C++)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-12 05:10 PM
What could go wrong?
does it have anything with the add-on manager? (I dont believe so cause im working with the demo version...)
Im stuck with this for hours already.bomber.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-12 09:00 PM
zanzibar wrote:Does this error occur when you run ArchiCAD in demo mode too? And which compiler are you using to build the add-on?
Active Thread Ltd
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-13 08:14 AM
And I'm using VS2005.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-13 09:53 AM
zanzibar wrote:I suppose I should ask the other obvious questions. Are you using the ArchiCAD 13 devkit? Note that devkits for one version of ArchiCAD are not compatible with another.
Yes. Iv'e tried this in demo mode only...
And are you compiling the correct word size for your target OS, i.e. are you building for 32 bits and running on 64 bit Windows or vice versa?
Active Thread Ltd
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-13 10:19 AM
correct word size for your target OSAnd yeah, I tried it several times : compiled as 64 bit in 64 bit O.S, and tried running it in a 64 bit AC13 (btw the devkit should be suitable).
I also tried that with 32 bit OS and AC and the same happend.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-13 10:48 AM
zanzibar wrote:'Word size' refers to the number of bits in the 'natural' unit of data for the target. This is typically the size of a memory address for the target.
Didnt understand what you mean by that:correct word size for your target OSAnd yeah, I tried it several times : compiled as 64 bit in 64 bit O.S, and tried running it in a 64 bit AC13 (btw the devkit should be suitable).
So to recap, you've already done the following:
- 1. Download the dev kit for ArchiCAD 13;
2. Open one of the bundled example projects using VS 2005;
3. Select the target to suit the host OS and ArchiCAD installation (32/64-bit) and build;
4. Copy the built add-on into the ArchiCAD Add-Ons folder.
Active Thread Ltd
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-13 11:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-13 03:38 PM
zanzibar wrote:I'm baffled. Try cleaning the project and then rebuilding. Does the add-on appear to build without error? In particular, are the resources compiled correctly? Check that the GRC compiler output is present and correct. It might be worth check all the project paths too - perhaps the project is linking against the wrong libraries.
Exactly. Iv'e done that several times and it didnt work.
Active Thread Ltd
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-13 04:36 PM
How can I check the GRC file? (I mean, what is CORRECT)? and which libraries are you reffering to?
Thanks a lot.
