Read more
Archicad Python API
About automating tasks in Archicad using the Python API.
Arguments of GetBuiltInPropertyId()
iu-tamura
 I know I can use GetBuiltInPropertyId as shown below example, but where do I find the arguments (element type and property name) such as "Zone_ZoneName"?
Is there a list somewhere?
<example>
from archicad import ACConnection
conn = ACConnection.connect()
assert conn
acu = conn.utilities
propertyId = acu.GetBuiltInPropertyId("Zone_ZoneName")
JT1986
Hi iu-tamura
You can list all BuiltIn- and UserDefinedProperties of a project by running the script below. If you run it in visual studio code or in Archicad Python Palette, the script should return available values to the terminal- / console-view. After that, you can copy and paste the printed result into, for example, Word and save it as a text document.
acc = conn.commands
act = conn.types
PropertyIds = acc.GetAllPropertyNames()
for PropertyId in PropertyIds:
    print(PropertyId)
Result should look like this (Taken from visual studio code)
-JT
JT1986
Hi iu-tamura
acc = conn.commands
act = conn.types
    print(PropertyId)
-JT
Thanks for your answer. I was able to view the property list!
