Archicad Python API
About automating tasks in Archicad using the Python API.
Container Change
Takahiro Oka
Beginner
Hello
Recently, I started using Archicad and setting up python.
For Setting up development environment I activated Python Palette.
However I couldnt set the specified Python container which is managed by venv to clean default environment.
Can we change that freely?
Thank you.
1 REPLY 1
Takahiro Oka
Beginner
I solved this problem by running code from VSC Editor with package that have installed from pip.
Thank you.
