Read more
Archicad Python API
About automating tasks in Archicad using the Python API.
Python Error Message
poco2013
Mentor
In Working with Python API, I am trying to change some properties using:error_msg = acc.SetPropertyValuesOfElements(elemPropertyValues)
With one element, WC 23, I am getting the error message of:
ERROR{'code':6001,'message':teamwork Permission Denied'}
As a test, I am using the Archicad Sample House plan 23 which I opened in 24.There appear to be three WC23 in the plan. one on the first floor and two on the ground floor. My return says there are 4 objects, however
Anyone know how to fix this?? I am not using teamwork.
Gerry
1 REPLY 1
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Gerry,
Thank you for reporting us this issue!
This is certainly a bug in our API. Next time please report bugs at our Support Portal (https://graphisoft.atlassian.net/servicedesk/customer/portal/5) or in email (archicadapi@graphisoft.com), that way we can response faster.
I wrote a script which detects ElementID conflicts and tries to generate unique ElementID for conflicted elements. Using this script I was able to reproduce your issue with the Archicad Hillside House Sample Project (https://helpcenter.graphisoft.com/knowledgebase/103415/) without using Teamwork.
from archicad import ACConnection
conn = ACConnection.connect()
assert conn
acc = conn.commands
act = conn.types
acu = conn.utilities
elementIdPropertyId = acu.GetBuiltInPropertyId('General_ElementID')
elements = acc.GetAllElements()
newElemPropertyValues = []
idConflicts = {}
propertyValuesOfElements = acc.GetPropertyValuesOfElements(elements, [elementIdPropertyId])
for i in range(len(propertyValuesOfElements)):
	elementId = elements.elementId
	elementPropertyValues = propertyValuesOfElements
	for elementPropertyValue in elementPropertyValues.propertyValues:
		propertyValue = elementPropertyValue.propertyValue
		if propertyValue.value in idConflicts:
			idConflicts[propertyValue.value] += 1
			propertyValue.value += f' {idConflicts[propertyValue.value]}'
			newElemPropertyValues.append(act.ElementPropertyValue(elementId, elementIdPropertyId, propertyValue))
		else:
			idConflicts[propertyValue.value] = 1
result = acc.SetPropertyValuesOfElements(newElemPropertyValues)
print(result)
I added this to our bugfixing short-term backlog and I hope we can fix this issue soon.
Identifier: DEF-1317 (Python API: SetPropertyValuesOfElements returns "TeamWork permission denied" error with Solo project)
