2023-01-17
12:19 PM
2023-05-20
12:34 AM
Gordana Radonic
Hello! I have problem with my backup file. It automatically saved my project but I want to use the previous file. (before the last backup file)
2023-01-17 02:16 PM
I don't think that is possible unless you use the Mac Time Machine backup functionality or a similar set up. The Archicad .bpn file will only be the last state of the project prior to the most recent save.
2023-01-17 08:27 PM
That can be done if you copied the project file with backup to a new folder and opening the project from this copy that will let you save a new backup file different from the older one which gives you the ability to retrieve the desired file version and start building upon in case you need.
