BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Backup file
Radostt
Hello! I have problem with my backup file. It automatically saved my project but I want to use the previous file. (before the last backup file)
Lee Hankins
I don't think that is possible unless you use the Mac Time Machine backup functionality or a similar set up. The Archicad .bpn file will only be the last state of the project prior to the most recent save.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
That can be done if you copied the project file with backup to a new folder and opening the project from this copy that will let you save a new backup file different from the older one which gives you the ability to retrieve the desired file version and start building upon in case you need.
AC 28 INT 3110/WIN 11
