Read more
BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Can't Publish to BIM
Cant publish my pln to BIM "publish to bimx" is not availabe cant be clicked
9 REPLIES 9
David Maudlin
isabelacruz:
If you are referring to BIMX, it can be saved from the 3D Window, not the plan.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
in 3d window but still can't publish to BIM
i am using archicad 18 64-bit
You can "Save As" and choose the BIMx option for a model you can move around, but for the BIMx Hyper-models (with links and 2D / 3D navigation) you need to purchase the BIMx Pro license.
s2art wrote:
...but for the BIMx Hyper-models (with links and 2D / 3D navigation) you need to purchase the BIMx Pro license.
Anyone should be able to publish a BIMx Hyper-model.
You just need to purchase a license to view it on your mobile device.
Check your Add-on Manager (Options menu) to see if the BIMx add-on is installed.
It should be as it comes default with Archicad (from version 17).
If it isn't active all I can think of is to repair or re-install Archicad.
There will be other posts here about BIMx not being available - it is just a matter of finding them.
i checked the add-on manager
how can i fix this: says error loading in bimx add-on
p.s: downloaded my archicad on torrent
So you don't have a WIBU or Codemeter license?
That would be why it doesn't work.
You must have a valid license for it to work.
do i have to uninstall and reinstall it again
Not if you don't have a proper (paid for) license from your local distributor.
It will make no difference - BIMx just won't work without it as far as I know.
