Collaborate forum
Importing Autocad Drawings Into Archicad
peach49
Can anyone help with this?
Im currently creating a 3d model in archicad of a site, which has a been surveyed in an autocad drawing.
In order to accurately get the levels onto the 3d model i need to somehow overlay my autocad drawing onto my archicad drawing so that i can draw on the contour lines from the survey. Can anyone suggest a way of importing an autocad drawing into archicad to scale so i can do this?
Thanks alot.
15 REPLIES 15
Thomas Holm
Please - I'm not here to read the manual for you. Just read the Help file, or the manual. You can even just drag the dwg file into a floor plan window.
AC4.1-AC24SWE-25INT; OSX11.5; MP5,1+MBP16,1
Or you can just place the DWG file using the Drawing Tool, then resize it in its Dialog.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
jrscholl
I have a question on importing 3D cad dwg drawings. Im trying to insert a 3D cad dwg of a site plan... the site dwg is already in a 3d format in Cad but when i import it into Archicad,it comes in as a 2d drawing... is there a certain reason for this or do 3d dwg's need to be imported differently then 2d dwg's? thanks, J
J.R. Scholl
Student/Architectural Co-op
MacBook Pro 15" Core 2 Duo
Mac OS 10.5.1
WinXP Pro
ArchiCAD 11
Revit 9.1
Matthew Lohden
ArchiCAD only imports 3D DWG as library parts. To convert 3D DWG to a site model you need ArchiTerra, but you will have to convert the DWG to DXF. I just did a very large site and it worked brilliantly (aside from the mediocre quality of the DWG file).
Matthew Lohden
Consultant, SF CA
MacPro 8core 32GB Radeon 5870
OSX 10.8 Mountain Lion, XP32, Win 7x64
Sanaa
I have a question on importing a cad dwg drawings. Please help
I'm new in using ArchiCad and I'm trying to insert a cad dwg of a site plan so I can use it to set up my design. How could do that?
thanks
Eduardo Rolon
Start to read from Thomas post above.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Sanaa
Where?
Eduardo Rolon
Second post from the top. OR start reading
page 386 "Drawings in Model Views" of ArchiCAD 12 Reference Guide
and
page 496 "Opening DWG/DXF Files"
and
in the help file search for drawing
OS X 10.XX latest
AC25 US/INT -> AC08
Here is an Archicadwiki article that may be of help:
http://www.archicadwiki.com/TechNotes/Using%20DWG/DXF%20Files%20in%20ArchiCAD
kliment
Sanaa wrote:
Where?
HERE!
Kliment Ivanov
http://www.klimentivanov.com
AC /since 4.55/; AutoCAD; Max; SketchUp; VRay; ArtL; Photoshop; Illustrator; InDesign; CorelDraw
Win 7 Ultimate 64
Sanaa
"Sanaa" wrote:
Can't I import a cad dwg drawings and convert it to archicad? Please help
thanks
Sanaa
Thanks kliment
Sanaa
Sanaa wrote:
Where?
Thank you eduardo
farzanehmirzay
how we can Importing PDF Files As Drawings ?
Eduardo Rolon
File -> External Content -> Place External File
If the PDF contains vectorial information, it is not an image scan, then you can right click and select explode.
OS X 10.XX latest
AC25 US/INT -> AC08
