Importing Autocad Drawings Into Archicad
Can anyone help with this?
Im currently creating a 3d model in archicad of a site, which has a been surveyed in an autocad drawing.
In order to accurately get the levels onto the 3d model i need to somehow overlay my autocad drawing onto my archicad drawing so that i can draw on the contour lines from the survey. Can anyone suggest a way of importing an autocad drawing into archicad to scale so i can do this?
Thanks alot.
15 REPLIES 15
Sanaa wrote:
Where?
HERE!
"Sanaa" wrote:
Can't I import a cad dwg drawings and convert it to archicad? Please help
thanks
laszlonagy wrote:
Here is an Archicadwiki article that may be of help:
http://www.archicadwiki.com/TechNotes/Using%20DWG/DXF%20Files%20in%20ArchiCAD
Thanks kliment
Sanaa wrote:
Where?
Thank you eduardo
how we can Importing PDF Files As Drawings ?
Eduardo Rolon
File -> External Content -> Place External File
If the PDF contains vectorial information, it is not an image scan, then you can right click and select explode.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
