opart wrote:
7.0 went on without a hitch. I stopped using a hardware key last year and as expected ArchiCAD would not start, however plot maker was a different story.
PlotMaker always ran without a key. I think if you download the Windows version of the AC 7 "converter" package from the bottom of the page here:
http://www.graphisoft.com/downloads/fileconverter.html
that you will find that THAT version of AC 7 will launch for you. You can then load the US libraries from your current installation.
It's not surprising that you had poor results exporting to DWG from an old version of AC. Many improvements to translation have been made over the years. So, Eduardo's approach is what I was incoherently recommending - bringing the PMK up to at least version 3.1 so that AC 19 or 20 could place it on a layout and export from there.
Glad you got somewhere, and shared what method got you there... and for Eduardo and Aaron to join us in the pain Graphisoft created by not recognizing older PMK files. Seems that if we can open/convert old PLN files, then PMK files from the same old versions should also work.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
