Christophe wrote:
Could you illustrate your words ?
Let me try.
If you want to find the ratio of building zones to the overall site zone (area), you can not do this directly.
The building zones have no idea what the site zone area is nor do they know what the other building zone areas are.
Likewise the site zone does not know what the areas of the building zones are.
You can add a property to the building zones where you can 'manually' input the site zone area.
Then you can calculate the ratio and you will have the ratio of one building zone to the site area.
For multiple building zones you can total the ratio in the schedule.
However for every building zone you will have to manually adjust the site area - which hopefully will not actually change.
But my point is that it is not a fully automatic process.
The zones (nor their properties) do not actually 'talk' to each other.
You can do all sorts of clever calculations with properties, such as rounding the length of a timber beam, or calculating the number of bricks in a wall.
But these are all calculated on a single element and then simply totalled in the schedule.
Is that any clearer?
Back to Thomas' original question.
Yes you could calculate some of those things (with or without properties), but it won't be fully automatic.
