Collaborate forum
"Warning! Cannot read file plan."
jetthvn
Hello, I was wondering if anyone has a fix for Archicad not allowing you to open shared downloaded files. Files shared between myself and the company architect will allow him to open the same file that I cannot. I have the most recent software update and all the same hardware specs as him. Would anyone know what to do to fix this? Below is a picture of the message I receive:
2 ACCEPTED SOLUTIONS
Lee Hankins
That error normally displays when you are trying to open it with the wrong version of Archicad. The only way you can work on a file at the same time together is through Teamwork.
Lee Hankins
ArchiCAD 4.5 - ARCHICAD 26UKI Intel 3010 and Apple Silicon
macOS Monterey (12.5)
As Lee said, the only time I have seen that message is if I was trying to open a file made in a new version with and older version of Archicad.
i.e. the file was saved in version 26 and you are trying to open it in 25.
If you go to the FILE menu > OPEN dialogue, and select the file, you should see the version number of the file.
If you see nothing it means it is a version newer that your currently open Archicad and can't be opened.
Versions 6.5 to 25
4 REPLIES 4
Lee Hankins
Lee Hankins
Steve1
Sometimes windows blocks downloaded files. Try right clicking on the file and opening the properties tab. If it has an option to unblock the file down the bottom of the general tab, tick that hit OK and try again.
Still no luck sadly.
Versions 6.5 to 25
