wrong wall area in schedules
Hi, I've got a big problem with schedules, both in Archicad 20 and 21. When scheduling walls I use inside and outside gross and conditional surfaces but I can't understand how the hell do they work! Why External and internal surfaces are identical (supposing I'm measuring a rectangle this is not possible!)? Why then if I have no holes at all, gross and conditional (or net) are different? It seams that for conditional it is not considering angles, but what I expect is that that must be the difference between inside and outside. Well, It's a huge problem, so please help me!!!!
Thank's to everybody!!!
Have a nice summer!
10 REPLIES 10
Gaetano
Thanks a lot to LaszloNagy and Marc H for the support and for answering my questions!
For LaszloNagy: looking at how the 3d body is generated, I was able to verify the correctness of the measurements and values ​​I sought! I don't think the differences in values ​​between the layers of the two composite walls, in my case, depended on the priority number of the intersection of their building materials because the two composite walls were made with the same materials and therefore had the same properties as intersection....
For Marc H: ... actually I have experienced that, between the two composite walls, the one with the layers of greatest surface and volume turns out to be the wall traced first, regardless of the direction of tracing !!! ...and yes! the diagonal cut would be unrealistic so I'm glad Archicad reasons as it does.
The really strange thing is the impossibility of pulling out the length and height of the various layers, because I think these data are already kept inside the drawing and it would be right for the programmers to bring them to light!
Thanks again, I hope I won't have to disturb you again, but I fear it will happen!
