We are currently experiencing issues with our cloud licensing service.
Our team is working hard to restore service as quickly as possible. We apologise for any disruption.
3D polyline, wire, tube or pipe lengths in schedules
boatingcow
Hi everyone,
Often at the early stages of design, I like to produce schedules of pipe and wiring lengths, where for any given 'diameter' or 'wire gauge', I can give an early estimate of the total lengths required (at a later stage in design, other software is used for the final component design, drawings and bills-of-material). At the moment this is slow and clunky. I'd like to be able to model splines (or arcs at least) and arbitrary direction changes in 3D. It seems I can have one or two but not all of these things...
In the past I have used:
> Spline: 2D only. Doesn't report length in schedules, have to export element information to a text file
> Morph: Almost perfect for modelling arbitrary 3D networks. Doesn't report edge lengths anywhere, so have to resort to manual measurement
> MEP modeller: Straight sections and radius bends only. Schedules list every individual item length, misses bend lengths.
> Beams (or walls) and columns with profiles: Fine for modelling orthogonal networks. Schedules list every individual item length.
> Shells (detailed): Plan only. Reports circumference rather than length.
> GDL objects: 3DMD, Oliver Dentan are close, but I'm not a GDL programmer so can't make them do what I need (yet)!
Can anyone suggest a better workflow than any of the below? I'd be happy to look at upgrading to a newer ArchiCAD, or investing a bit of time in GDL, but as the morph tool is so close (already reports areas and volumes) maybe I'm missing a trick already?
Thanks for your help.
ArchiCAD 24 | Dell Precision 5750 | 32GB RAM | Nvidia RTX 3000 6GB | Windows 11 Pro
sinceV6
Hi.
Looks like you have explored almost all options. Would be great if morphs could report edge length, but until then I think GDL is your best bet. You can use the poyline script I posted or the one Mariosmic added.
You can use the "Freccia zig 14" object, from the object depository. Although it reports a full length distance, it is practically 2D; but could give close enough estimates.
Best regards.
I thought about a similar issue regarding dimensions scheduling for morphs and i wonder
If it could be possible to use the algebraic formula of getting the distance between X1,Y1,Z1 and X2,Y2,Z2 spatial points ?
And just a another related question. Is it possible to report radial and angular dimensions in schedules?How about as dimensions in preview image?
