About Schedule - How to set the Qty in another column
Schedule's Issue 1:
For the elements, the schedule are made for showing the quantity. However I could only showing the quantity of the item at the same column. (See Fig. 1 and Fig 2). Is there any solution for make the quantity at the column behind the item.
Schedule's Issue 2:
The schedule's information could be saved as Excel file. However the saving could only be one by one. Is there any way for saving multiple schedule as excels one time? (Fig 3)
Kent wrote:
Schedule's Issue 1:
Schedule's Issue 2:
Kent wrote:
Kent wrote:
Schedule's Issue 1:
Schedule's Issue 2:
Kent wrote:
Schedule's Issue 1:
Schedule's Issue 2:
Not sure I understand what you mean by 'behind' in issue 1. If you mean that you would like the quantity in a new column, that is not possible
For issue 2, create a Publisher Set and use publisher to save all of your schedules at once.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
