2003-12-11 07:46 PM
2003-12-19 08:04 PM
2003-12-19 08:30 PM
2003-12-20 11:12 AM
2003-12-22 10:10 PM
2003-12-25 07:59 AM
Matthew wrote:I guess that would depend on what you are actually after as a result of this "shootout". My impression has always been that you need to EXTRACT OUT the "Architecture" and emphasize the CAD... So it should not be a DESIGN charrette but a PRESENTATION charrette.
This year the event was called the CAD challenge rather than shoot-out because of the format change. From what I understand it was becoming difficult to impossible to get enough vendors to sponsor teams (for a variety of reasons). I believe that Geoff is trying to find a new way to convey a meaningful comparison of the different CAD softwares and how people use them in a real situation.
In previous years it was a true shoot-out and quite intense for the participants. It seems his experience with these previous event could be informative in setting up this one (AC v Revit).
I assume that this event would be web based. Does anyone have some ideas as to how it might be structured?
- Who would create the program? (A neutral party presumably.)
- Who would execute the work? (Vendors and/or users.)
- What would be the constraints? (Time, staff etc.)
- How would it be presented? (What are the deliverables?)
2004-02-24 04:24 PM
2004-03-13 02:41 AM
2004-03-13 07:02 PM
Scott wrote:1. Special Snap Points - any existinfg linear element or the edge of a polygonal element is divided to given number of dicisions, or by lenght or distance, by the full lentght or the part defined bty two intersections
Special Snap Points? relative construction constraints? Omnipotent Magic Wand?
2004-03-13 07:39 PM
I've noticed a few things that Revit is unable to do that we seem to take for granted
2. Relative construction constraints: Perpendicular, parallel, bisectrix, offset, multiple offset, and a free floating Special Snap Points toolRevit has all of these, just with different terminology. Geometry 'snaps' to other geometry, or displays 'apparent' snaps with reference lines.
3. Magic Wand - can generate any polygonal element to any closed or almost closed outline (scloses the outline automatically) or trace any linear element along the polygon's perimeter. Also can be used for subtracting, joining, adding polygonal elements. The main culprit fora house in six clicks.Revit tools react in the same way, its not magical. I can use the 'pick' tool to trace underlying DWG lines, or Revit geometry. TAB key while hovering over a line with the pick tool will select the chain of elements. The only thing missing is a 'close' option, although the program will highlight where the opening occurs, and a quick fillet tool will close the sketch. I expect a 'close' option to be added soon.
