ArchiTerra selection
I am looking for the way how to select Plateau or Road objects in 3D view created by ArchiTerra ? I can select only the whole Mesh object in 3D? Is there any settings for that?
1 REPLY 1
Fabrizio Diodati
It follow the standard ArchiCAD logic about overlapping elements:
you can use the tab key to switch between the several overlapping elements selection or, activate the ArchiCAD object tool (Road and Plateau are objects!) to give "priority" to the object selection...
Friendly
Fabrizio
Fabrizio Diodati
