Archicad 23 Goodies Suit won't install
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-11-11 02:46 AM
Any ideas please?
I've repaired installation. removed & reinstalled installation & still no luck.Version:
Archicad 23
4006 INT FULL
Installer:
Goodies_Suite-23-AUS-3003-1.1.exe
Intel (R) Xeon CPU E5-2620 v3 @2.4GHz
RAM: 32GB
System: 64 Bit
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-11 08:36 AM
The language version needs to match I would assume.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-11 04:12 AM
Or it could just be a case of re-applying the standard WE.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-11 07:19 AM
Here is screenshot of standard WE, still no Roof Accessories or Design Extras avaiable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-11 07:38 AM
The problem with that is that shows your current list of menus.
You don't have the 'Accessories' menu yet.
You need to create it.
On the right hand side open the 'Design' menu then the 'Design Extras' menu.
If there is no 'Accessories' menu click the 'Menu Options' button and create a new menu.
Now on the left list 'All commands in alphabetical order' and you can search for and add the commands you want.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-11 08:00 AM
Think its not installing to start with...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-11 08:34 AM
The goodies are for build 3003.
You probably have a newer build of Archicad.
So you may need to apply the latest update (hotfix) again - this will update the goodies.
The latest build is 5010.
Don't forget you will also need to load the accessories library which will be created in the Archicad program folder (but that shouldn't affect the work environment - you just won't have any accessory objects to use).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-11 11:01 AM
I'll D/L the INT Goodies version then...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-11-11 11:12 AM
Installed Goodies INT version.
All seems to be installed now.
Will make sure my W.E. doesn't block out all the Goodies selections.
Thanks so much for your assistance.
