Archicad object revert to default settings when file is saved or published as .dwg
Steve Jepson
 Is there some way to prevent this besides exploding the drawings first? Perhaps I have some setting in the Translator configured wrong ?    For example, I joists objects that have been stretched to 20' will all be at the default length in the .dwg.  Shower Tray make 3'x5' will revert to 3'x3' in .dwg....
I am using AutoCAD 2022 and Archicad 25 objects for this.   anyone else have this issue?
Miha_M
If it's a library object which is giving you trouble, take a look here:
Solved: Kitchen Layout Object - Goes Bonkers When Saving D... - Graphisoft Community
| Archicad 4.55 - 27
1 REPLY 1
Miha_M
| Archicad 4.55 - 27
