Autotext in DWG
martin-b
Is it possible to publish autotexts from Archicad that will keep their functionality also in DWG?
What I need is a File Path Autotext in a DWG-file, that will show the DWG's location.
When I place such autotext in Archicad, it tells me the Archicad files's location, but when exported/published to DWG, it just becomes a static text with its previous contents from Archicad.
Scott Boyd Turner
Unfortunately no, auto-text is exported as regular text when converting to AutoCAD dwg.
File name and path are fields in AutoCAD not regular text.
Regards,
Scott
MSI Creator ZP16, i7-12700H, 32GB RAM, RTX 3070 8GB
Guru
Within AutoCAD you could create an Block with the Attribute Definition of the save location. I do not believe there is a way to automatically convert an Autotext into a a Block with an Attribute Definition.
Ling.
