Read more
CADIMAGE Garage door
is there a setting for the door not to intersect with the frame? it seems there isn't
1 REPLY 1
Good question! The door really shouldn't do that, very difficult to open I would think. We'll fix this ASAP.
In the meantime you can work around it by setting the 'Door Side Room' to a negative value. This will make the door narrower. If the frame width is 30mm, set the 'Door Side Room' to -30mm.
