Read more
Cadimage Stair Builder
gpowless
I'm trying to get Stair Builder to show full stair above the home storey. Does anyone have a clue where this setting might be? Thx
Intel i7-6700@3.4GHz 16g
4 REPLIES 4
have you tried in the model view options?
gpowless
Yes. There are settings there but I can't find anything for the storey sensitivity.
gpowless
Figured it out.
You have to move the breakline location on the upper storey. Not a bad operation considering there are times one needs to break the stair going down as well.
gpowless wrote:
Figured it out.
Since you figured this one out, you might be able to help me out here as well. I cannot find the setting for the line type of the stair display above the home story. It keeps on showing up as a dashed line only (this is on the story above the home story only). Any idea where I find that setting?
Found it. I had "enable object's linetypes' unchecked. Funny. Even with it unchecked, the linetypes on the home story did change per Cadimage Stair settings, but the "above home story' display wont't change unless this is enabled.
