About model- and data exchange with 3rd party solutions: Revit, Solibri, dRofus, Bluebeam, structural analysis solutions, and IFC, BCF and DXF/DWG-based exchange, etc.
Composite wall & Take-off
I had a Composite wall shown a 6" masonry block, 1 1/2" air space and 1/2" of gyp. bd. The problem is when I use the List Element Basic under "Thickness/Size" it's read as a 8" wall instead of split the fills/material as assigned. What I'm doing wrong?
Djordje
Ace
Are the materials defined properly in the assigned Property object?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks for that tip, let me check and after vacations I tell you if works or not.
