Read more
Copying from DWG
Hobbesnb
Has anyone else noticed that AC15 won't let you copy directly from a DWG opened up in a separate instance of ArchiCAD?
Often times, when I'm pulling details from manufacturers, I'll open their DWGs in one instance of ArchiCAD, modify pens/fills/etc so I can avoid corrupting my working file, and then copy those elements I want into my primary instance of ArchiCAD. I used to be able to do this without a hitch, but now I have to save the DWG as PLN before I can copy elements between files.
Is there a setting somewhere to change this? Most of the time, i'm not even interested in preserving copies of the source DWGs, so having to save a duplicate in PLN format is a nuissance.
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
0 REPLIES 0
