Database recommendations?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-09-16 08:18 PM
‎2009-09-16
08:18 PM
Or, anybody using 7.0 and tried it on 10.6?
thanks
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-16 09:01 PM
‎2009-09-16
09:01 PM
Hi Rick,
Somebody else will have to give a good Mac-answer to this one.
I, too, have a copy of Filemaker 7 Pro (Mac) from some years ago ... bought for a project that never happened. I have used Microsoft Access on Windows for many years, and found Filemaker significantly inferior ... and so I still use Access on my Mac, under Parallels Desktop.
Ignoring all of the programming, query, and report power that Access had over that version of Filemaker ... a big one with respect to ArchiCAD is the concept of 'linked tables'. Access will allow you to link to a text/CSV file, as well as Excel, etc .. not just other Access databases. So, you can publish schedules from ArchiCAD that are automatically updated in all of your Access reports. To my knowledge, even recent versions (no idea of current version) of Filemaker would only permit linkage to other Filemaker tables - not text/csv.
Hope to learn more from others who post answers to your question!
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-16 09:08 PM
‎2009-09-16
09:08 PM
Thanks.. I started out with Access 1.0:) Switched to Filemaker when I went Mac, which was when I went AC4.5. Filemaker has always been problematic for me, but I assume it's just my resistance to that sort of program
I see freeware ones out there, but I don't want to start over again, too old for that trip, so I'll probably end up coughing up the $300. I can't believe they make you buy a full license again.
thanks
thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-16 09:18 PM
‎2009-09-16
09:18 PM
Rick wrote:I use FileMaker Pro 7 on 10.6.1, but I've only used it lightly so far. I haven't seen any problems at all and comments I've read from others say the same. Plugin developers have published that their software works too, which is encouraging. I suggest that you back up regularly and give it a try.
Currently I am on version 7, which has current issues under 10.5, and is not recommended for 10.6, or so I understand.
...anybody using 7.0 and tried it on 10.6?
Ralph Wessel BArch
Central Innovation
Central Innovation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-16 09:22 PM
‎2009-09-16
09:22 PM
Karl wrote:I've worked with Access too, but didn't find it superior to FileMaker in any way - which features made the difference for you?
Ralph Wessel BArch
Central Innovation
Central Innovation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-16 10:03 PM
‎2009-09-16
10:03 PM
Ralph wrote:For ArchiCAD, primarily the one I listed: being able to live-link text/CSV files into a database project. (You just use 'link' in the Tables area.)
(More generally, the powerful reporting and programming via Visual Basic and visual interface creation, with tons of sample code to borrow from. Also, queries with field renaming and math, and inner/outer joins with visual drag and drop query building as well as SQL for when tabular queries are insufficient.)
If FileMaker has addressed any of these issues, I might switch, since at least it is cross-platform - I think?
Thanks,
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-16 10:11 PM
‎2009-09-16
10:11 PM
Great news Ralph... I don't use any plug-in, so ...
thanks
thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-16 10:18 PM
‎2009-09-16
10:18 PM
Ralph, I assume it needs Rosetta, so I should install that and also select that under "get info"?
thanks
thanks
