Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Dimensions
Q257
When I click on multiple walls and then click to bring up the hammer only the thickness dimension of the individual walls appear and not the dimensions between them. If there is one dimension in place I an ctrl/click and the line will be extended to as many objects as you want. Some setting has changed and I can't find what it is.
You have probably activated the 'Single Click Thickness' button in the dimension geometry settings.
Q257
Absolutely correct Barry, I didn't even know that button was there. Many thanks.
