2021-12-08 04:13 PM
Can anybody assit or guide me in creating a parametric object, similar to the attached (parametric Sketchup model) of a construction fence that will follow a line on an uneven terrain surface?
I used Profile Builder 3 to create a profile and somehow managed to have it follow a path on a terrain, but not very good result and want to try and create a similar object in Archicad 25.
We make a lot of Site Layout plans in 3D (see image7) and its really the fence that's the most time-consuming to place.
Would Param-O be a possible way forward?
Best regards
Jesper
Solved! Go to Solution.
2021-12-08 05:08 PM
Have you tried the railing tool? You may even be able to create the support feet as custom posts.
2021-12-09 02:31 AM
Custom post with two railings and a texture for your wiring.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2021-12-09 08:02 AM
Haven't really worked much with the railing tool, only used predefined railings, but it might be a solution.
Best regards
Jesper
2021-12-09 08:03 AM
Thank's, yes I might have to learn how to create new railings.
Best regards
Jesper
