Hotlinked Element:Expression cannot be evaluated
Hello All,
I wish and hope that you are well and healthy!
I wanted to create some schedules based on objects. I have created Expression based properties.
They output only if objects are native and not hotlinked.
AC outputs schedules of hotlinked elements but does not output values of these expression which are referring to hotlinks. Please see the uploaded image.
Is there any alternate?
Kindly replay ASAP.
Thanks in advance.
Regards,
14 REPLIES 14
Minh Nguyen
Dear Narendra,
Thank you very much for your comment!
Unfortunately, as I mentioned previously, the expression cannot be evaluated if it is placed in a module. The Evaluation function also gives you this notice, if you look at the screenshot in my previous answer. I believe this is a limitation with the Evaluation function, as it works more like a preview to test the function.
I am very sorry for the inconvenience! I highly suggest reporting this through your local reseller in order to ask for higher priority.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Andreas _kerlund
Hi!
Saddly I can report that the problem still exist in Archicad 25. In autotext labels as well as in schedules.
We had the same problem in AC23. It makes me sad when bugs don´t get fixed over several versions....
Andreas Åkerlund, Arkitekt SAR
Arkitekthuset Jönköping AB
ArchiCAD 5 to 25
Windows 10 64 bit
Intel i9 7920x @ 2.9 GHz, 64 GB RAM
Minh Nguyen
Hi Andreas,
Previously, I did some experiments with a custom expression, and the result is that the expression works well in labels and schedules. May I ask for the expression you are using that does not work in labels/schedules for in-house reproduction?
Best regards,
MInh
Minh Nguyen
GRAPHISOFT
CaticonC
Hi, i have the same problem, i need to create schedules from zone properties that are made based on expressions, and the schedules don't give me data. I hope Graphisoft solves rthis problem. Working on Archicad 24
ArchiCAD 24
Windows 10
AMD Ryzen 7 2700 CPU @ 3.20GHz
Radeon RX 570 Series 4 GB - 32 gb RAM
Can you show a screenshot of the Property Manager Dialog that shows the Expression defined for the Zone, and another screenshot that shows what happens in the Schedule?
