How to import AutoCAD Civil 3D topo into ArchiCAD 14
Hello all
I have been tryint to find what is the best and easiest way of importing AutoCAD Civil 3D topographic drawing into new/existing ArchiCAD 14 file.
Your help is greatly appreciated.
Thank you very much
Steve Jepson
.3ds
ArchiCAD 25 6000 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
Srinivas
Not sure which version of ArchiCAD you are using, but from ArchiCAD 14 you can import XYZ points to create your terrain, if you have those from your surveyor, here's Video on how to do it.
In case you have only the contours in your civil 3d without the XYZ points then either you can import the contours from civil 3d as a 2d dwg drawing and recreate the terrain with the mesh tool or import the 3d dwg file as an object to view in ArchiCAD 3d, although the later one won't provide you with flexibility as it will be imported just as an object.
Hope this helps.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
