IFC 4 issue with Door type
daviddelven
IfcDoorStyle should be deprecated detract from IfcDoorType.
(http://www.buildingsmart-tech.org/ifc/IFC4/final/html/schema/ifcarchitecturedomain/lexical/ifcdoorst...)
Am I do something wrong with IFC2x4 Schema management in ArchiCAD 21 ?
Thanks mates.
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
8 REPLIES 8
felcunha
Hello David,
Do you mean IFC4, and what is your precise need ?
(if you prefer you can formulate your question also in Spanish, maybe I'll understand it better).
Felipe Ribeiro Cunha
AC 26, macOS Monterey
I will bring this to the attention of the IFC team at GS HQ.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
daviddelven
Thank you, Laszlo!
And Felipe Ribeiro Cunha, indeed, I mean IFC4 (or a.k.a. IFC2x4) schema release. English is already fine, here. Let the Spanish away in this forum 😉
Hi David,
I have received info from GS HQ. They said that information on the User Interface is coming from IFC2x3. For technical reasons they cannot continually switch UI elements based on the version of IFC selected, I am told.
However, when the actual IFC4 Export/Import occurs, it correctly works with IfcDoorType, and not with IfcDoorStyle as the IFC2x3-based UI suggests.
daviddelven
Thank you, Laszlo!
Good to know about it. We hope there's some alignment update with IFC releases in UI, from time to time, to avoid some misunderstandings.
I will publish your answer on my professional network.
Hello
However, when the actual IFC4 Export/Import occurs, it correctly works with IfcDoorType, and not with IfcDoorStyle as the IFC2.3-based UI suggests.
That may work on IfcDoorType. What about IfcBuildingElementProxyType? PROVISIONFORVOID is possible in IFC 4. However, this cannot be selected in the type assignment of the IFC translator.
Thanks
Caspar
Caspar wrote:
Hello
Thanks
Caspar
I got the following info from the developers:
At the moment IFC4 can only be supported in "compatibility" mode, since IFC4 itself is still under certification.
However, there is a question for you:
Why do you need support of PROVISIONFORVOID for IFC4 export. This is an entity type that usually MEP programs generate (these Voids, I mean), and they are imported into ARCHICAD. So it is understandable in case of import, but why do you need it in case of export from ARCHICAD?
stefan
I was trying to export an IFC4 file with this type for the indication of openings to be coordinated. It is a recommended practise in the Dutch USO (Uniform Openings/Voids Specification).
As the internal scheme uses Ifc2x3 no IFC4 classes or types can be selected.
Archicad26/Revit2023/Rhino7/Unity/Solibri/Zoom
MBP2023:14"M2MAX/Ventura+Win11
ARCHICAD-user since 1998
Archicad Book
