2022-11-01 10:28 AM
In the IFC translator, when modifying the 'model filter' then the settings are never saved. I spent already 10 hours trying to figure it out but i couldn't. any tips ?
2022-11-08 09:37 AM
Hi POTS,
the saving of the model filter state has a bug in it, according to which changing a parent checkmark wont be saved but if you check/uncheck child types saving will work just fine. In your case in the attached picture try unchecking "IfcOpeningElement" and "IfcVoidingFeature" and this should be a workaround for the time being.
I know it's a bit more hustle, but it will get the desired results and we will try to address this bug as soon as possible.
2022-11-08 09:43 AM
Dear Zoltan,
I appreciate your answer. We knew at the office about the bug, but im afraid even changing the parent doesnt work anymore.
The IfcOpeningElement shows in other software / ACC and highly unwanted by our clients, I have to explain to them already for months that we have a bug in Archicad, that I cant do anything about it, that's quite embarrassing, I personally dont know why Graphisoft doesnt fix it immediately. Is there any expected date for the fix ?
2022-11-29 01:43 PM
Hello everyone, developers,
Do you know if this issue is fixed in the update 4 of Archicad 25 ? It's not on the list of solved issues.
