IFC export/import Revit
TeresaM
Hi!
I have a problem to coordinate IFC Base Point and Survey Point with Revit. When I open IFC model created in Revit ( SCREEN R) it shows Base Point and Survey Point which I set up also in my Archicad model (SCREEN A). But when I import the same IFC model it shows up at the base point no matter if I save it with different geometry preferences. The same problem appears when we open exportet Archicad IFC - even if I set up the Base Point and Survey Point, the model always appears in the Base Point in Revit. How can I solve this problem?
SCREEN ASCREEN ASCREEM RSCREEM R
0 REPLIES 0
