Import RFA 2020 files to AC 22
tsturm
I tried to import some American Standard RFA files into AC22 6025 using the RFA importer. I got an error message about the converter not supporting this file format. Only supporting 2011 to 2018. When is this importer going to be updated as it seems the manufacturers are making their objects in newer versions of Revit. Likely due to the reason they are on subscriptions and forced to the change.
As we all know, Revit has no backward compatibility. Once the file is in a newer version, you cannot go backwards.
Anyone finding a way to get around this using some other software such as Sketchup?
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
Hello tsturm,
Archicad is able with this: https://bim6x.com/store
Revit is not able to do it for Archicad 😉
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
tsturm
thank you
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
