2005-04-15 08:26 PM
2005-04-17 02:58 AM
2005-04-17 07:37 PM
Karl wrote:Karl,
The I.S. cannot do what you want (AFAIK), Dan.
I think your post, and several others, will demonstrate to GS that users want to (and have wanted to) extract data in a reasonably visual and interactive way and so are asking the I.S. to do more than it was designed to do.
The easiest resolution would be to export the data for each element type and combine it in Excel/etc. On the PC, the ODBC driver might be an option to dynamically generate the information in Access (or Filemaker - I've only used Access so far).
(AFAICT, the list schemes do not offer the capability you want either. Just a quick look ... no experience to base that on.)
2005-07-12 10:18 PM
2005-07-12 11:13 PM
Laura wrote:Yes, unfortunately I believe this to be the root cause of the problem. The Interactive Scheduler cannot handle "additional parameters" from two different "element types" AFAIK.
Is this why it does not appear that we can listboththe door object and door marker parameters in a schedule?
archicad-talk.graphisoft.com/viewtopic.php?p=41531#41531
This is very unfortunate...
2006-06-20 09:39 AM
Karl wrote:Karl,
2006-06-20 11:50 PM
2006-06-21 01:23 AM
Geoff wrote:I think that's about the only thing you could do.
Is there no way to pass the data from the Zone to the window so the schedule could read it all from one element?
2006-06-22 09:53 AM
Geoff wrote:Geoff,
