Modelspace as flattened drawing
In AC9 there was an option called "Modelspace with cropped drawings content" which gave me the output I wanted when exporting my layouts
- single DWG-file
- complete layout in modelspace
- layers exported
In AC10 the option "Modelspace as flattened drawing" comes close but:
no exported layers, everything is on layer 0
The Paperspace options also do not give me what I need.
Am I overlooking an option?
- single DWG-file
- layers exported
I just ran into this problem myself. Put the setting on
Save Layout into : Paper Space with Cropped Drawings content
Place Drawings into : Single DXF/DWG file.
You will get the full drawing in model space and a croped view in paperspace, all layers intact.
- single DWG-file
- layers exported
Yes, you should read the AC10 New Features Guide or the AC10 Help file, because these options have changed in this latest release. This I believe mostly has to do with PlotMaker integration into Archicad.
I have tried all your suggestions, also from this thread, but i can't get everything that is on the layout to apear in model space (including objects on master layout) and with layers. I can get either everything on one layer, or only model with layers, but without objects from master layout.
I'm sure, that I am missing something, but I think I have tried everything allready. Or this can't be done.
