Read more
My new self made IFC translator doesn't work.
m_ziolo_86
I've just made my own IFC translator and I can't use it at all. It seems to be locked on the list, I can't even edit it's options. Anybody had similar problem ?
It seems that Archicad doesn't create any .xml file for new translator, since I checked the translators folder.
Regards
Archicad 16, Win 8.1
5 REPLIES 5
David Maudlin
m_ziolo_86:
I made an IFC Translator and it is an xml file stored here: user/Library/Application Support/Graphisoft/IFC Translators 16.0.0 USA. Perhaps you have a permissions issue.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
m_ziolo_86
I've made signature. Just as you suggested. Any idea what to do with the problem with ifc translator ?
Send info to a private box, it will be easier because the Polish
David Maudlin
m_ziolo_86:
You can try Duplicating the locked translator to create an edible copy. The IFC Translation Setup dialog box shows the Location of the translators at the bottom of the Available Translators panel.
Dwight
Code goes down easier with mustard.
Dwight Atkinson
