Problem with window/door schedule;
I have a problem with window schedule, everythig looks fine and all of sudden few windows change their appereance in floorplan view, this happens on randomly on few windows while others are fine, and I cannot figure what is happennig.
1 REPLY 1
Anything to do with the renovation filter being used for the schedule?
If you are opening the schedule from the Project Map then you set the reno filter to be used.
If you are opening the schedule from the View Map then the reno filter being used is set in the view settings.
Versions 6.5 to 25
