Property Sets - What Can I Do With Them?
Ok, I've enabled the IFC2x3 Property Sets in my Tool Settings Scheme. I've got a spanky new tab in my settings dialog boxes with them.
The Graphisoft User Guide refers to them, but I still don't understand how they are really meant to be used. This manual is vastly improved over the first one, but there is more work required here.
Has anyone who knows got a practical example they could share? Like how you would configure a Favorite with this tab enabled to export, say, a wall, a plumbing fixture and a beam (LVL, wood or steel, your choice).
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
7 REPLIES 7
You can work a lot slower. Every time I select something IFC tree wants to rebuild, compile, etc.
Suggest only turning on when actively preparing IFC exports.
Krikey.
Rhino 8 Mac
MacOS 14.2.1
I found the same slow behavior while testing last year. I unloaded the IFC add-on just so I had no chance of being slowed down - or having extra IFC data stored in my projects.
One of the forum moderators
Erika Epstein
You don't have to unload the IFC addon(s), just create a Work Environment that has them turned off in the Tool Setting Dialog Boxes.
Work Environment> Tool Schemes>Tool Setting Dialog Boxes
Just switch work environments when you want to access IFC
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika,
Meisterstuck!
Rhino 8 Mac
MacOS 14.2.1
I'll have to check IFC later (dinner time!) ... but for most add-ons there is indeed a difference between making them invisible to the user and unloading them. Many add-ons, merely by being present, run initialization code which stores stuff inside your project file.
That's why when you open the project on someone else's machine where an add-on isn't present, you often (depends on the add-on) get a warning dialog asking if you want to keep the data associated with the so-and-so add-on, or delete it. I'm not convinced that all private data associated with the add-on is truly deleted. Maybe it is. Haven't tested it, and having been burnt a few too many times, I don't believe much until I test it. 😉
If just hiding the interface to IFC eliminates the slow down, then that is great.
Thanks, Erika,
PS But, still hoping someone will answer Aaron's question.
Erika Epstein
There is quite a lot of information on this on the Building Smart website
http://www.iai-tech.org
but to me
http://www.iai-tech.org/psd/IFC2x3/final/index.htm#Link0548F7E8
it still is not user-friendly enough to decipher
On the other hand, on the IFC tab many of the properties listed are self-explanatory. Not all are applicable to the building architecture but instead address related disciplines and phases such as Interior Design, Construction and End-user occupation.
A dictionary would be welcome.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
