SCHEDULE EXPRESSIONS - SOLUTION TO WINDOW WIDTH ISSUE?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-04-26 06:51 AM
IF (Length > 0, Length, Width)
Unfortunately it didn't work. Any ideas of how to make this work.
Archicad 27 USA (full), Macbook Pro (16-inch 2023, M3 MAX, 128 GB RAM)
- Labels:
Data management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-26 07:25 AM
That is you are using in the same expression, both length and width . Width can only be used for windows, etc. and length for curtain walls. -- As you have said. So, any window or curtain wall which sees both attributes will mark one or the other as not applicable and fail.
The solution is to make two separate sequences (expressions) in the same expression using the ADD button,
One which will apply only to windows and one which will apply only to curtain walls. In evaluating the expression, the program will only use the applicable sequence for the correct element.
FYI: make sure you have correctly set the classifications for both elements.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-26 05:20 PM
The way I wrote the expression was super simple. I just added 2 separate entries in the expression editor, one for Length and the other for Width
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-26 06:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-26 07:10 PM
I'm guessing the problem is with your schedule criteria. Would need to see your expression formula(s) and the schedule criteria Screen shots
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-26 11:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-26 11:14 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-27 12:40 AM
You could change the ID's to be different or Just change the expression to return a string instead of a number.
STR ( {Property:General Parameters/Width} / 1 ft, 2 ) -- returning string
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-27 02:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-27 03:37 AM
STRCALCUNIT ( {Property:General Parameters/Width} )
Unfortunately, this changes the units for all expressions and schedules -- no way around this -- for now
