Firstly you have set up 'Component' schedules, so they will attempt to list the components of the elements.
One (the 'Error' one) is searching for the 'Layer' criteria, so it is listing every component that is in that layer.
The other one ('No Error') is not searching for the layer criteria. I don't quite understand why this would make the schedule not show the individual components though - as it is obviously still filtering the same elements.
If you want to schedule the entire element as one item, I would use the 'Element' type schedule.
