Read more
SQL Parameters
Entering the "SELECT parameters FROM Objects" gives me all Parameters of every Object. they seem to be in one extra table in the column "Parameters". How can I Select Objects having one single Parameter (f.e. "testparameter001" in common.
6 REPLIES 6
Akos Somorjai
The SQL queries are not supported any more officially (the last supported version was ARCHICAD 18 ), so don't rely on them. Someone else here may be able to answer you question.
Sorry, Akos
But it still works 😉 (AC 20) I just can't find the right syntax For objects.parameters
Ralph Wessel
Mentor
I'd strongly recommend not using unsupported technology – you're setting yourself up for a disaster. If GS hasn't updated it beyond 20, the fact that it appears to work is coincidental and almost certainly unstable.
Ralph Wessel BArch
runxel
Legend
The command is already removed in 21. It's sad, but I guess there were just too few users who actually used it.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Actually it works fine with:
SELECT LIBRARY_PART_NAME, XX.PARAMETERS.NAME, XX.PARAMETERS.VALUE
FROM FLAT( OBJECTS, PARAMETERS) AS XX
BUT ehen I whant to add
WHERE XX.PAREMETER.VALUE=1
I get an error that It cant transform datatype GDLVARIANT to typ 1. I tried to use
CAST (XX.PARAMETERS.VALUES AS *) * for "*" I tried: "CHAR", "VARCHAR" or "string"
But the error remains the same. Can somone tell me how to transvorm a "GDLVARIANT" into something I can use? THX
Mihaly Palenik
Try to use this query:
FROM FLAT(OBJECTS, PARAMETERS) AS XX
WHERE CAST (XX.PARAMETERS.VALUE AS CHAR(50)) = '1'
It works in ArchiCAD 20.
Best,
Mihály
